You can set a throttle curve by using the AFR section of the model menu. Simply use a point or spline curve and adjust the points needed to give you the curve you want.
Speech is not available for the timer function in the 18SZ.
We don't know what changes/updates Futaba may have in process. They let us know when they make a release.
