Originally Posted by
bogbeagle
Yes, you simply withdraw the starter when the engine is firing. It works very well and I've used this reliably on model engines as large as 350cc.
Very good! I have an unused 1/2 inch drive socket surplus to requirements that I can machine off for the job. I'm guessing it should be welded to the steel plate with a high tensile (low hydrogen) rod, or MIG welder. I could try it first by welding the offcut piece of the socket with a mild steel rod, then seeing if it will break easily.
Choosing this option over the spinner and cone drive means I don't have to wait weeks for mail order items to arrive.
