RCU Forums - View Single Post - Stihl MS660 big bore conversion.
Old 04-28-2016 | 12:34 PM
  #113
Jim.Thompson's Avatar
Jim.Thompson
Originally Posted by spaceworm
Speaking of gaskets, have you checked your vacuum hole from the engine to te carb. ................
Yes, all clear. The pump is pumping, as I can see the fuel move along the line when it is only part full and I turn the engine over.
I am in the process of organising the parts for an electric starter. Also, my mechanic buddy said that we should make sure the spark is working when cranked at slightly higher revs than I have been able to achieve.
Discussion here: http://www.rcuniverse.com/forum/begi...-starters.html
