Originally Posted by [COLOR=#000000
Can someone send me a picture of what the wings or fuse would look like RIGHT before you apply the base coat?? Should it be completely Covered in Primer or Sanded primer..[/COLOR]
FalconWings;12212379]Johnny, in reality a blend of sanded primer. I normally do a last light coat of primer for "self verification", to make sure there are no imperfections, as the solid color of the primer makes it easy to spot them. And then just sand it off with a wet 800.....ends up looking like sanded primer.
Falcon is spot on.. Just try to keep the final primer coat as light as possible. These high build primers are heavy.
