Powerbox Electronic Switch - Lipo Recommendation
I recently ordered a Powerbox electronc switch (dual lipo running at 7.4 volt version). This unit will be used to power up (5) high voltage servos with a total capacity of 524 ounces of torque, according to Spektrum.
What size lipo battery do you recommend and it is advisable to use the same capacity for both batteries or one larger as the primary and a smaller (lighter) as a secondary.
