From all the info given by the OP and assuming the correct model was chosen on the TX, it seems that the turbine was still seeing a command of full throttle given by the Rx. There was no power loss nor Rx blackout since the turbine continued to run at full throttle. All ECU will shut down if there is no power or no signal from the Rx. Seems it is the Rx at fault here.
