I am having an issue with seeing the wings level also. I think the issue is that the color scheme causes the wing to blend into the fuse making it hard to see the wings and determine wings level. I am thinking about changing the pattern on the fuse and making more white space by painting over a couple of the stripes. Someone suggested that I use a white masking tape first to see if it makes a difference before I paint it. I have only had one day in months to fly so I have not had a chance to try it. Makes sense to me. See if that helps you.
