Hi Vince,
I generally use the stock setting of 20 for the compensation factor. On the higher power setups, I might increase it a little bit to 22 to 24. Depends a lot on batteries used, flight time, and ambient temp. I've not adjusted it (or my throttle curve) very much during my testing phase, as it is easier to discern differences in motors / props if I leave the Throttle Tech and throttle curve unchanged.
Originally Posted by
vbortone
Hi Dave,
Thanks for all that good information. I am setting up one V4 now. Are you using the Throttle Tech? If yes, what is your settings recommendations for compensation factor.
