RCU Forums - View Single Post - Broken Piston Ring question
Old 05-30-2016 | 09:11 AM
1QwkSport2.5r's Avatar
1QwkSport2.5r
Originally Posted by Murphey
I was given a small twin cylinder gaso engine...no idea of the manufacturer...looks to be about a 40cc, but haven't measured it. In inspecting the engine, which appears to have never been run, I see that it has 2 piston rings per cylinder...the lower ring of 1 cylinder is broken. Assuming (yes, I know) everything else is OK mechanically, what would be the impact on performance by removing the broken ring from that cylinder and removing the good one from the other...It seems to me that the single ring configuration is more common in small engines that double rings...thoughts?
M
Most guys that run gas engines that have twin ringed Pistons would often remove both stock rings and install a high quality reproduction ring and just run a single ring. Running with a single ring of better quality than stock will yield a bit better ring seal and also reduce friction.
I dont run gas model engines, but I've read a lot about them. I'd not hesitate to run a single ring in a twin ringed piston.
