Hi Brenner
I have a V4, and received replacement bearings from the dealer I purchased from - Jason Arnold in Australia. The drive has not been run.
1. The replacement bearings are identical part number (S6900RS, yellow seals) to those in the drive. Should I still go ahead and replace them?
2. The pinion gear rotates freely on the collet even with the bolt done up - am I missing something?
3. Any suggestions for Spin 99 ESC settings (Kontronik pyro 600-09).
Thank you
Andrew
