Thanks Pat. By hand, you almost can't help but cut the edges. I had a couple on the first stab. Also put a dent in it with a finger nail...I had to step away it ticked me off so much. What do you use to fill these with the minimum of pain? It's not terrible and I'm tempted to just leave it alone.
Tried to order the buffer but had problems checking out. How do you set up an account there? My failed attempt to check out was as guest. What other pads, etc does the buffer need to make it useful?
Good guy? Only the best.....
