Originally Posted by
siclick33
I can't remember off hand about the update process but are you leaving the battery plugged in to the Cortex while the update is being performed?
When start the update process it tells me to turn off the TX and disconnect the motor and then turn it back on. Since I don't have it connected to a RX or in the fuse. I am assuming that I would just disconnect the battery and connect it again. At that point it starts to download and it get all the way through as if it downloaded and installed and then it gives me the " update didn't work"
