RCU Forums - View Single Post - 10 cc gas engine
Old 06-29-2016 | 06:26 PM
prigai
Originally Posted by triumphman49
Have Rascal 80 and GGT10, but have concerns of hi-idle and slowing the plane for landings. What sort of idle are you seeing?
The Rascal is a high wing light design that floats on landings, if you want to reduce the idle to a reliable low idle you can consider an on board glow plug igniter such as this one: http://www.hobbyking.com/hobbyking/s...r_1_5V_4A.html
Mix it with the throttle servo to ignite when reducing throttle under 1/3 or 1/4, similar devices are often being used for 4 strokes and large glow engines.
