10 cc gas engine
Old 06-28-2016 | 06:34 PM
Default 10 cc gas engine
Best 10 cc gas engine
Old 06-29-2016 | 09:27 AM
I give up - which one is it?
Old 06-29-2016 | 01:06 PM
Thinking that might be his question.
If so, my answer would be the jury is still out on the 10's. There's no clear winner - yet.
Old 06-29-2016 | 01:34 PM
Maybe you should start with the application you need it for.
There is no clear winner in all cases, your best option is to search for threads or reports about the engine you consider.
I don't have an Evo 10 but do have the OS GGT10, NGH GT9 and RCGF10, each has its strengths and weaknesses.
Old 06-29-2016 | 01:53 PM
I'm looking for a 10 cc gas engine for my sig kadet senior any help is appreciated thanks
Old 06-29-2016 | 01:55 PM
I'm looking for a 10 cc gas engine for my sig kadet senior thanks
Old 06-29-2016 | 01:57 PM
Is the os ggt 10 cc better than os gt 10 cc?
Old 06-29-2016 | 03:01 PM
OS has only the GGT10 to my knowledge using a G5 glow plug, OS offer a GT15 and GGT15 in the 15cc range.
The GGT10 is easily convertible to a GT10 by adding a EI ignition (1/4"-32 spark plug).
I prefer the simplicity of the Gas Glow G5 plug for small engines but others will have different opinions.
The GGT10 is a well made engine in the tried and tested OS tradition.
Old 06-29-2016 | 04:27 PM
You are right thank you
Old 06-29-2016 | 04:29 PM
My Feedback: (149)
Have Rascal 80 and GGT10, but have concerns of hi-idle and slowing the plane for landings. What sort of idle are you seeing?
Old 06-29-2016 | 06:26 PM
The Rascal is a high wing light design that floats on landings, if you want to reduce the idle to a reliable low idle you can consider an on board glow plug igniter such as this one: http://www.hobbyking.com/hobbyking/s...r_1_5V_4A.html
Mix it with the throttle servo to ignite when reducing throttle under 1/3 or 1/4, similar devices are often being used for 4 strokes and large glow engines.
Old 06-29-2016 | 08:45 PM
Do you think an os ggt 15 cc is ok for a sig kadet senior?
Old 06-29-2016 | 09:05 PM
Probably an overkill but why not? just be careful with your throttle control, you can probably tear the wings apart.
The OS GGT10 is probably more suitable and will result in a lighter plane. It is probably equivalent to a .60-.70 4 stroke.
Old 06-29-2016 | 09:10 PM
Would you recommend os over evolution gas engines?
If you plan to move on to something more lively later, the GGT15 will give you better options.
If you want only one engine (for now as well as later) get a GGT15 they are almost the same price.
Old 06-29-2016 | 09:49 PM
Never had an Evolution, (but I have an MVVS which is a great engine) so cannot comment with any level of knowledge or experience.
Users like them so they must be good, nothing against the engine I just don't have a good supply source.
From the ones I have experience with, OS is still superior by quite a margin, it is the better designed and manufactured engine.
Old 06-30-2016 | 03:42 AM
I've seen several Senior Kadet/Evo 10 rigs fly. Plenty of power for good sport flying the Kadet.
Agree a 15 would be too heavy for it.
Old 06-30-2016 | 06:06 AM
GSXR1000's Avatar
My Feedback: (7)
I have a 1st gen non pump EVO 10 in a Sig Tclips and it has plenty of power for it... and it's a great running motor and still run strong. you can tach it with hand held or get a plug in digital tach to get your high and low settings correct... You are going to be running your batters behind the cg to get it to balance correctly on most planes.
Old 06-30-2016 | 10:23 AM
fromadvisor's Avatar
And what about the rcgf 10cc??
https://www.rcgfusa.com/rcgf-10cc-bm-2
Old 06-30-2016 | 11:40 AM
Looks good on paper!
Old 06-30-2016 | 12:17 PM
Hey, guys wich engine is better os ggt 10 cc or evolution 10 cc for a kadet senior? Thanks
Old 06-30-2016 | 01:13 PM
What do you think about os and evolution 10 cc gas engines?
Old 06-30-2016 | 02:22 PM
It looks better on paper than in the hand, since I like the rear carb and one piece cylinder design, I ordered spares to assemble 2 engines (less ignitions and mufflers). Quality of most parts look OK and some even look good (pistons, crankcases), I have a concern with the quality of the cylinder heads, they certainly do not look pristine inside! will require a bit of polishing work in the transfer ports, cylinder inner surface is not great either, nowhere near an OS GGT10 quality. My advice if you are not an engine builder to stay with the OS (or Evolution) known quality.
Old 06-30-2016 | 03:47 PM
Thank you I really appreciate it.
Old 06-30-2016 | 04:19 PM
The Evo 10 comes with an Electronic Ignition module but can be used with a G5 glow plug.
The OS 10 only comes with the G5 plug but you can fit an aftermarket ignition module (and magnet).
Either will be a good choice, don't try anything else, you will spend time and money to get it to work.
