RCU Forums - View Single Post - What is the minimum needed for gsu to display data (on bench, old p80) TIA
Old 07-04-2016 | 05:36 PM
Jetkopter
Blue can means its really old !! sounds like you have either a bad data cable or some wiring wrong . Do you have a proper charge on the ecu battery, and you must also have power on the throttle lead from the rx as well . Do you get and backlighting on the gsu data screen or is it dark? There is no minimum speed it works the same with the engine off as it does at full rpm.
