Originally Posted by
rt3232
Thanks guys
I had an idea that a ESC would work and would need a bit of help I am not sure a 7C would let me do it, I do have some old servos that might work but was not able to find an article with the instructions.
I finally found a ready made switch from Hansons so Got that coming, but would still like to find the servo thing.
Cheers Bob T
The brushed esc would be the simplest and the cheapest way(provided you have one lying around) . It will work on a 7C.
As far as using a servo,here are some videos I found . Not the best soldering jobs but it gets the job done.
If you are powering the lights from the receiver voltage.
https://www.youtube.com/watch?v=Ap-Md1W8dYQ
If you are using a secondary battery or higher voltage battery you add a relay:
https://www.youtube.com/watch?v=wKdIMsmYJ08
