RCU Forums - View Single Post - Os .25 fsr
Thread: Os .25 fsr
Old 07-19-2016 | 05:05 AM
1QwkSport2.5r's Avatar
1QwkSport2.5r
Originally Posted by gerryndennis
G'day Tim,
Every OS I've seen has the arrow on the piston pointing to the exhaust port. Hopefully that's the way yours ended up?
Dave H
Greetings Dave H!
This engine didn't have a factory marking on the piston - it was a marking from the previous owner. The previous owner said he either marks the piston for the exhaust port or carburetor. In this case, it was the carburetor/front of engine.
The engine ran no differently with the piston installed in either direction. It's fairly worn - the piston seal isn't that great, so it won't idle super low. 2,800 is the brink of quitting. It doesn't hand start very well either. But it holds a needle setting and peaks at 11,200rpm on a 10x6 and 16,000rpm on a 8x6 (APC) using 10% nitro. Ran it with a Davis head and my own diesel mix and got 11,200 on the same 10x6 I ran on glow. Compression screw buried - contra not flush with chamber yet so it might give a little more power with a longer contra screw. Would not hand start on diesel either. I think it could use a new piston/liner (iron/steel).
