Originally Posted by
wfield0455
Jeti also has some 2100 mah and 2700mah 2S Lipo receiver packs in addition to the Lithium Ion packs they sell.
http://www.espritmodel.com/jeti-rece...v-li-poly.aspx I've used them in a couple of airplanes and they seem to be quite good. For a plane that I wanted to use 5000 mah 2S pack I used pulse.
Hi Wayne, jeti does not make or sell lipos. Those are some other lipos that the USA distributor is putting his shop label onto, and since his shop name includes the word "jeti" it is misleading you into thinking they are jeti branded products.
I use Jeti li-Ions for radio and for the turbine, simply to reduce the risk of lipo fire at home.
