RCU Forums - View Single Post - Help can't stop the Bubbles and Sucking in of the UAT
Old 07-25-2016 | 06:57 AM
mikes68charger
My Feedback: (34)
Originally Posted by sysiek
change the 4mm to at least 6mm on suction from tanks to uat this might be the problem + eliminate all the reductors connections 4to6 and 6to4 make all one larger size at least 6mm .
Thanks, that did help on a skymaster F15 I was having a hard time getting max rpm with.
This UAT I have never had before, it has a huge 8 size nipples on pump and suction side, instead of putting the 8-6 adapter so close to the UAT I will put size 8 line to the tank, then put the adapter.
Its crazy to me, I have a AMT 450 at 48 pounds of thrust just using plane 4 size line with no issues, but it dose have a huge pump!
