RCU Forums - View Single Post - Help can't stop the Bubbles and Sucking in of the UAT
Old 07-27-2016 | 07:57 AM
Zeeb's Avatar
Zeeb
My Feedback: (41)
Originally Posted by mikes68charger
I was thinking of Connecting an air compressor to the fill line and fill the whole fuel system at 10psi or so and spray with Windex to look for leeks, What do you think? The main tanks are plastic, so Im not so worried about blowing up a tank.
Might I suggest that you use a bit of soapy water rather than Windex? May I also suggest that you get yourself a couple of syringes with say 18G needles, sand the points off and use that to apply the soapy water exactly where you want it?
Just suggestions for leak checking.
