RCU Forums - View Single Post - Jp 4
Thread: Jp 4
Old 08-05-2016 | 09:01 PM
manchu9inf
Some work was done on the lower hull, the zimmerit is looking pretty good,just need to the weather to cooperate and get some more primer on the suspension parts.
Gary, there are other version you can do without the zimmerit, this is going to be an earlier version with the shorter 75mm L48 gun built before AUG 44. if you are wanting to build the version with the long barrel L70 gun you can easily build it without the zimmerit.
Name:	glacis plate.JPG
ID:	2175913   Click image for larger version
Name:	front hull 2.JPG
ID:	2175914   Click image for larger version
