RCU Forums - View Single Post - Jp 4
Thread: Jp 4
Old 08-07-2016 | 05:57 PM
  #33
manchu9inf
If you are interested in how i do zimmerit, here is the way that i have figured that works best for me:
I use Milliput, a hobby knife handle as a roller, a modified flat head screwdriver with the tip filed down at an angle to apply the pattern.
Step 1: scar the surface where you want the zimm, gives the milliput something to stick to
Step 2: roll the milliput flat
Step 3: Cut out the size you need
Step 4: place on model and roll it on using a roller
Step 5: Use a screwdriver to apply the pattern
Step 7: Continue until the surface you want zimmed it complete
I find this method ideal, the milliput has a long drying time to allow mistakes to be corrected, is easily sanded when fully dried, and is rock solid when completely dry and very durable. It is maybe a bit on the time consuming side, but the effects achieved i think are more than worth it.
Name:	JP4 Zimmerit 1.JPG
ID:	2176147   Click image for larger version
Name:	JP4 Zimmerit 2.JPG
ID:	2176148   Click image for larger version
Name:	JP4 Zimmerit 3.JPG
ID:	2176149   Click image for larger version
Name:	JP4 Zimmerit 4.JPG
ID:	2176150   Click image for larger version
Name:	JP4 Zimmerit 5.JPG
ID:	2176151   Click image for larger version
Name:	JP4 Zimmerit 6.JPG
ID:	2176152   Click image for larger version
Name:	JP4 Zimmerit 7.JPG
ID:	2176153   Click image for larger version
Name:	JP4 Zimmerit 8.JPG
