Originally Posted by
Ash Creek Flier.
I have one with the gps to go into my new build.Have not used it yet but I did notice if your running a 7.4 volt system all servos half to be 7.4 volts.Theres no channels you can regulate down to 5.9 volts its one or the other.
Uh huh! have you looked at how compact this is for a 3 axis gyro 15 assignable output unit? Where are they going to put more regulators?
You can use most 7.4v servos at 5.9v...they will last longer and 'beat' on the linkages and surfaces less!
