Hello, I am preparing 1st flight of my 2m10 Cmpro Cessna
I still have a doubt with cg value...
From where do you take the dimension ?
I calculated cg with software and found 120mm !!!
Very far from suggested 70 or 80mm
80mm is applied on the middle wing ( bolted on the fuselage ) or in the side wing
There is 30mm between the middle and side wing starting edge
