Originally Posted by
TheBennyB
Sounds like a another part for Daryl to improve on. If you make the trunion/traverse bracket out of aluminum should reduce some deflection. This was the same problem with the JP.
I haven't built the JP, but i think the problem is at least twofold: one, is how they have the elevation arm with that flimsy bent piece of metal that hooks into the recoil mount and second, the whole system isn't balanced well, i cant imagine how it would flop around with even the longer barrel.
