RCU Forums - View Single Post - Can my Canopy be saved ???
Old 08-29-2016 | 08:05 AM
rhklenke's Avatar
rhklenke
My Feedback: (24)
Originally Posted by hsukaria
For removing the dulling from the CA debonder, would you need more than Novus part 1, "Clean and Shine"? I don't have any scratches to fix.
You probably would. The CA debonder, like the DEET, I think, melted the surface of the plastic. You need to remove that material with a more abrasive solution and then polish out the scratches that the abrasive leaves behind.
For deep scaring on canopies (and my car headlights) I have used 1000 and then 2000 grit wet sanding followed by the "Novis" type progressive system shown above...
Same technique as for removing scratches in automotive-type paint finishes - wet sand and then polish, polish, polish...
Bob
