RCU Forums - View Single Post - FPV & Part 101
Thread: FPV & Part 101
Old 09-01-2016 | 05:41 PM
franklin_m's Avatar
franklin_m
Originally Posted by porcia83
You keep asking why you can't get responses from the AMA, why they won't respond to you, or listen to you, or implement the suggestion you make/have made. Of course you get them, because you usually post their responses right here, they just aren't the responses you are looking for. In one instance you kept asking Chad the same question what, 10 times and you kept getting the same response, but kept pushing and pushing. Pretty sure Chad was smart enough after the first question to know what was going on there.
If you keep approaching something the same way, and keep getting the same result you complain about, I think I've said before you probably need to change your approach. If one method doesn't work, try another. The whole squeaky wheel thing only works so far though.
Multiple questions result when organizations try to obfuscate their response rather than use precise language. I went several rounds with Chad because he did the classic media thing, answer a different question than the one I posed.
