Originally Posted by
Brandon.c
Seems a little expensive but if it does the job then that's good. Would the Clarke board come with all the necessary wires etc? As I couldn't see if if it does.
yes they are a lot more expensive but they are in a different league to the stock electrics...run a IBU'ed tank next to a standard HL you'll see what I mean..
as to the wires etc, I would presume so, but best to check with the supplier, not sure who that is on your side of the pond..
