Originally Posted by
Brandon.c
Seems a little expensive but if it does the job then that's good. Would the Clarke board come with all the necessary wires etc? As I couldn't see if if it does.
Brandon, Most after market control boards do not come with much in the way of cabling because most of them be it "CLARK" "IBU 2/3" or "ASP" are more or less Plug and Play so the makers assume you will be using the existing cables already in your Tank.
But a full set of cables already fitted with plugs can be gotten from most dealers for just a few $$,
I would be surprised if "IMEX" were unable to supply you with them.
Shaun.
