RCU Forums - View Single Post - Rc5hl
Thread: Rc5hl
Old 09-16-2016 | 02:03 AM
CaptainB
Brandon, before you buy the Clark TK22, make sure you understand what you want. this board needs a few modifications done to the wiring on the tank for airsoft to make it run. the board does come with 4 cables that connect directly to your standard RC receiver. the rest of the cables you need to either have or supply yourself. Read the notes on Clarks website very carefully. Most of us on this site have had to learn the hardway with Clark boards.. They work well but do need a bit of technician work to sort out - mine came with the cables wired back to front from the diagram. Also, some wiring on the HL tanks, particularly the 8 pin connector was back to front for the Clark board but not on all tanks?. Also, the programmer can be a bit hit and miss in set-up too. Not terrible problems to solve but will frustrate you initially if you encounter them.
cheers
CaptB
