Pat
Sorry, Late follower, Earlier in the Thread there was a discussion about removing an existing finish and whether or not it is better to sand it off or chemically strip it. I believe you said strip it.
Can you recommend a process and products to strip an existing finish with minimum damage to the underlying structure. I have a composite fuse I need to strip and I am interested in if the process might change for a wing with prepared with Silkspan as you described.
