RCU Forums - View Single Post - What am I doing wrong?
Old 10-04-2016 | 11:30 AM
c_makhija
Default What am I doing wrong?
Hi Guys,
Got these 8 pin connectors from emcotec for my rebel pro, so I can have ailerons, flaps, gear and brake on one connection.
Maybe I understood the Emcotec guy wrong or am I doing something wrong.
The + of ailerons and flaps are joined together on one pin and the - of ailerons and flap are joined together on another pin. The signal wire of both are on 2 separate pins.
The + - of gear and brakes are simple.
The problem is when I hook up everything the ailerons and flaps seem to work fine for around 15-20 min then the servos start to gitter.
wires are all new and heavy gauge.
Need help as this is the first time I am going 8 pin.
Thanks.
Chatty.
