RCU Forums - View Single Post - SBD-1 decoder with R2008SB receiver
Old 10-20-2016 | 02:13 AM
malcolmholt
Default SBD-1 decoder with R2008SB receiver
I am trying to help someone set up an S-Bus system using an R2008SB receiver and SBD-1 decoders.
I have set the channels (1 – 3) on a decoder and everything works correctly when I test it with my own R7008SB receiver. When the decoder is connected to the R2008SB receiver the servos still respond to the correct controls but oscillate violently.
An S-Bus servo plugged directly into the S-Bus port on theR2008SB responds correctly without any buzzing or oscillation.
We have experimented with two different R2008SB receivers and three different SDD-1 decoders but always with the same result.
Is there a compatibility issue between the R2008SB and theSBD-1 decoder? If not, have you any other suggestions?
Thank you
