Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
SBD-1 decoder with R2008SB receiver
Old 10-20-2016 | 02:13 AM
Default SBD-1 decoder with R2008SB receiver
I am trying to help someone set up an S-Bus system using an R2008SB receiver and SBD-1 decoders.
I have set the channels (1 – 3) on a decoder and everything works correctly when I test it with my own R7008SB receiver. When the decoder is connected to the R2008SB receiver the servos still respond to the correct controls but oscillate violently.
An S-Bus servo plugged directly into the S-Bus port on theR2008SB responds correctly without any buzzing or oscillation.
We have experimented with two different R2008SB receivers and three different SDD-1 decoders but always with the same result.
Is there a compatibility issue between the R2008SB and theSBD-1 decoder? If not, have you any other suggestions?
Thank you
Old 10-21-2016 | 07:12 AM
Bax
We checked this on the bench. When an R2008SB receiver is used with an SBD-1 and analog servos the servos act exactly as you mention, but if we put in digital servos everything works correctly.
When an R7008SB receiver is used with an SBD-1 and analog servos everything works correctly.
The higher frame rate of the R2008SB w/SBD-1 vs. the R7008SB w/SBD-1 is the reason.
R2008SB w/SBD-1 – 6.7ms frame rate
R7008SB w/SBD-1 – 15ms frame rate
Old 10-21-2016 | 07:48 AM
Thank you. That provides a solution, albeit the more expensive one of using digital servos. More importantly, it reassures me that I am not going completely mad.
