Originally Posted by
bert269
I am a little baffled by step 13 in the fuse build. If you look carefully at the plan, it looks like the aluminum cabanes goes in between two ply layers P6 and P8 - (although P7 and P8 are not marked, but according to the plan it looks like it P6 & P8). Then you put a T-nut (blind-nut) in from the bottom side, but the sharp edges of the t-nut (that goes into the wood) would hit the aluminum cabane strut!!
I'll did some research in the other thread for the Hog Bipe Build, but could not find anything regarding this.....maybe I'll cut off a portion of the sharp points, so that it can only go into one the the plywood plates.
You say the kit was a few years old. I just bought mine two weeks ago from Tower Hobbies so here are two pictures from the drawing showing the side and front views of the cabane, plywood and blind nut stackup in case things have been updated. Also you can get the latest PDF manual at
http://www.sigmfg.com/cgi-bin/dpsmar...osF.html?E+Sig
Do you see any differences?
