I run a 14x6 Xoar on my 1.00 T, my guess is that it's dropping the right cylinder. The air bleed hole is invisible on the right cylinder, bend about 3/16" of paper clip 90 degrees and try to insert it in the right carbs air bleed hole. If it won't go in, the ab is too rich, (too closed), if it goes in easily turn the ab screw cw until it hits the paper clip wire, that should be ball park. I know that the picture doesn't help, but at least you know that I have one.
Jim is correct on the more load idea, it enhances cylinder filling and therefore raises combustion temperature.
