Originally Posted by
Decker79
The BME has the sensor magnet behind the hub. With that said, will a rcexl module work with the existing sensor?
Maybe ....
If it is a compatible Hall sensor, you can probably rewire it to work with an RCexl, RCXP / RCAME or CH ignition. I have done that a couple of times on Brison engines that use the sensor behind the hub. If that fails, CH should be able to make a sensor that will fit the application. You may want to call CH and visit with Adrian.
