RCU Forums - View Single Post - Replacement ignition module for BME 44
Old 11-30-2016 | 03:34 PM
BadAzzMaxx
The sensor will work with any of the ignitions posted here.
If your connector for the sensor is Futaba type it will work with no modifications.
If it has the small deans connector it will plug into the Futaba, there is a grove on one side of the connector. Just have it on the white wire side of the Futaba connector.
The only problem with doing this is it will enlarge the pin and a regular Futaba connector will not make contact if you try to use one.
Milton
