RCU Forums - View Single Post - Taigen Tiger GearBoxes
Old 01-13-2017 | 09:02 AM
Imex-Erik's Avatar
Imex-Erik
You might want to trim that post down a bit that touches the lower hull, that hopefully should help a bit. You might also want to see if it is the lower hull drooping and not the upper hull pushing on it. If it is the hull drooping a bit we do have some braces that can help. Does your tank also have the front brace on it near the gearboxes?
