Originally Posted by
GermanTanker91
It's the lower hull. It's not bad it's just enough for dirt to get in at times. I'll try dremeling down the posts and see how that works
Just a hair, try around 1/4" first.
GermanTanker91
And yes it does have the brace going across the gearboxes
We do have those same braces in stock here, you can also run a brace along the middle there, that should straighten up the lower droop. They are pretty cheap if you need one, I've got them on the site here:
http://www.taigentanks.com/requests/t1brace
