Originally Posted by
GermanTanker91
I did a run yesterday with my Tiger through the woods and frozen mud and I did notice it could use a bit more weight to it. It goes around great. But on small hills and on the leafs it tends to stop and slide in place. I think I'm gonna wait on the metal tracks and put some weights in it but my question would be how much weight would be a good start and keep the weight near the front or distribute it evenly?
Definitely try to evenly distribute it if you can, the con with adding weight to the lower chassis is it will raise the center of gravity. You want to try and distribute as best as possible. The Tiger 1 metal early version tracks I just weighed at 3.25lbs or 1.625lbs on each side
Hopefully that gives a good starting point.
