Here is mine completed, came in at 8 lb 7 oz with the 95AX. It is very well built but the covering is like Mac Tac. Not your typical heat shrink covering. The glue is not heat activated but sticky all the time. Never seen anything like it. Hopefully it holds up OK. You have to be extremely careful with heat. Even with the heat set on low with my trim iron it melts.
