RCU Forums - View Single Post - Full Scale Flying speed vs scaled down RC flying Speed?
Old 01-19-2017 | 06:48 AM
radfordc's Avatar
radfordc
My Feedback: (14)
Originally Posted by alasdair
However, for realistic scale flight in which the radius of turn of the model is the correct scale fraction of the radius of turn of the full size (at the same bank angle and angle of attack) we can say that the ratio of the weights must be as the cube of the Scale Factor. For the one fifth scale example again that means dividing the weight by 5[SUP]3[/SUP] or 125 so for our 20% scale Hurricane, scaling the weight by the cube rule would give an eight foot span model with a weight of 60.8 lb. The wing loading is up to 96 oz/sq.ft. The result is rather a heavy, fast flying, model which is smooth and realistic in manoeuvres.
Another interesting concept of "scale flight" is "time". If you could scale time the same way you scale a model it would be possible to achieve perfect scale flight appearance....both with the proper speed in level flight and with the proper bank angle and turn radius.
A way to scale time is to film the model in flight and then show the video in slow motion. Take the example above of the heavy Hurricane model flying fast but with the correct turn radius. Showing that same flight in slow motion the bank angles and turns will look correct and the overall speed will also look correct. This is in fact how movie makers often film models to provide a true visual allusion...ie. The Battle of Britain: "The other need was for models in aerial sequences, and art director and model maker John Siddall was asked by the producer to create and head a team specifically for this because of his contacts in the modelling community. [SUP][Note 4][/SUP] A test flight was arranged at Lasham Airfield in the UK and a model was flown down the runway close behind a large American estate car with a cameraman in the rear.[SUP][citation needed][/SUP] This test proved successful, leading to many radio-controlled models being constructed in the band rehearsal room at Pinewood Studios. Over a period of two years, a total of 82 Spitfires, Hurricanes, Messerschmitts and He 111s were built.[SUP][19][/SUP] Radio-controlled Heinkel He 111 models were flown to depict bombers being destroyed over the English Channel. [SUP]"
[/SUP]
Here is an example: https://youtu.be/Q8bAMyKeB30
