Originally Posted by
gunradd
Unless its a crazy good deal I would not get a turbine that's out of warranty. If you do happen to purchase it I would send it in for service just to make sure everything is good. If it has a bearing issue from sitting so long it would get real expensive real fast if it takes out the compressor or turbine blades.
why would sitting cause a bearing issue? if it's new never run the bearings should be fine. they are greased at the build time.
