RCU Forums - View Single Post - Cutting G10?
Thread: Cutting G10?
Old 01-23-2017 | 05:42 PM
acdii
Originally Posted by dbacque
I used to use G-10 for building boomerangs and I've cut quite a bit of it. First of all, wear a good respirator. That dust is extremely bad for you!
A band saw does work well but yes, it will destroy your blade. Actually, it'll grind the teeth completely off the blade. I've heard of using carbide tipped blades but they're expensive. I had some old blades and I'd use them until the teeth were gone.
Dave
That what I thought, better get another blade for my saw then. I treat the dust same as sanding a Corvette, very carefully.
