I will have to wait for the titanium rod ends to arrive from Central Hobbies but I did get some work accomplished today. I made the servo extensions and installed the servos into the bottom wing. I also installed the aluminum skid plates onto the aileron for those "Not so perfect landings." Went without issue.
Rubber grommets used to "finish" the servo extension holes. Not needed but they make it appear as if you cared.
SunDevilPilot
