About running your motor on 12 volts. The general rule with motors and speed controls is the higher the voltage the lower the amount of current you will draw. So in theory, yes I would imagine a system designed to run on 24 volts might not be able to handle the increased amps it would draw at 12 volts. But it would not affect the motor, it would be the speed control that would take the hit.
