RE: run testing an engine!
glow fuel..
i think you'll need glow plugs, a glow stick too... and maybe a prop.. then a way to control it, i dont use servos, just a push rod trapped under the band holding the tank when bench testing
best way to test an engine is to stick it in a plane, that way you got all you need there
