RCU Forums - View Single Post - What will happen?If I remove dihedral from wing?
Old 02-02-2017 | 11:23 AM
JohnBuckner's Avatar
JohnBuckner
Originally Posted by foodstick
John, do you keep the typical washout in the wingtips with your anhedral wing?
Foodstick on the four I have done over the years, the first back in the sixties I just used generic trainer wings and what ever degree of washout that may have existed. They all became very aerobatically inclined trainers however that were a joy to fly. Never have understood the resistance to this simple kit bash. There is however one draw back and that is it is more difficult to maintain orientation at first until one becomes more used to the unusual visual configuration so suggest keeping close on first flight even though it is a trainer.
And indeed what is pointed out above by buzzard bait, this is not for a mid or a low wing airplane. If this is done to a low wing the stability will diverge away from that neutral ideal.
A low wing always needs a small amount of dihedral or dihedral effect from airfoil taper and wing tip design. A mid wing needs no anhedral or dihedral, a midwing airplane is the only configuration that is already near that totally neutral ideal. Perhaps maybe that's that's why all the many great flying sport aerobats are midwings
Here are some random photos during the bash of this last one with the hacksaw (the trainer is a Midwest Aerostar trainer mostly stock except the wing.
John
Name:	Taxi Dancer may 3 2010 001.jpg
ID:	2199325   Click image for larger version
Name:	Taxi Dancer 15 007.jpg
ID:	2199326   Click image for larger version
Name:	Taxi Dancer 15 009.jpg
ID:	2199327   Click image for larger version
Name:	Taxi Dancer 16 001.jpg
ID:	2199328   Click image for larger version
Name:	Taxi Dancer 16 008.jpg
ID:	2199329   Click image for larger version
Name:	Taxi Dancer 15 001.jpg
