Ok so the first thing I would try is CaptainB's suggestion of checking if the safety switch is off. It is located on the top of the turret under the loader's hatch. Next if that doesn't work I would check to see if the red LED on the turret mantlet illuminates when you try to fire. If not then the 8 wire cable from the motherboard to the turret or the 3 wire cable from the upper hull daughter board to the turret may not be connected. Now if it is firing and you are not getting track recoil or sound then that is just a recoil switch issue (most likely not plugged in). If you haven't sorted this out yet please feel free to contact me direct at
[email protected] and I'll make sure you are taken care of
